H1 wheels on a H2?
Old 09-30-2007 | 08:51 PM
h2dan's Avatar
Default H1 wheels on a H2?
will H1 wheels fit on a H2?i believe they both are the same bolt pattern of 8x6.5 but what about the offset and will the 16.5" wheel clear over the stock brakes?
Old 10-02-2007 | 06:24 AM
GorillaH2's Avatar
Default RE: H1 wheels on a H2?
I doubt it would fit but isnt the H1 wheels a lot wider than the stock H2 wheels and maybe it would rub
Old 10-02-2007 | 06:49 AM
hilljob26's Avatar
somebody has to have tried this b4
Old 10-02-2007 | 10:54 AM
shortbus's Avatar
i think the center hole is larger on the H1 wheel than the hubs on the H2. the bolt pattern is the same, i know a lot of people that have put H2 wheels on an H1, and they had to grind out the center a bit. as for the rims fitting over the brakes, don't know that one, but my guess would be no, since the H1 brakes are inboard. not sure how the geared hubs fit behind the rim, so maybe there is room. try calling the service department at your local dealer, someone there should have the answer. then you could share with the rest of us.
Old 10-02-2007 | 07:52 PM
Muddydawg75's Avatar
The H1 and the H2 have the same bolt pattern. H2 wheels have a smaller hub. H2 wheels are 17" X 8.5". You have to machine the hub out 3/32's so the wheel will fit on an H1. I don't know that the load capacity of the H2 wheel is enough for the H1. The backset of the H2 wheel is not the same as the H1. The backset of the H2 wheels are 5.625". This means that they stick out another 1.375".
Old 10-02-2007 | 08:44 PM
beachman's Avatar
Would love to see what it looks like
Old 10-02-2007 | 10:20 PM
shortbus's Avatar
go to h u m v e e . n e t and you'll find plenty of posts of guys putting H2 wheels on H1s, even having them set up to work with the CTIS. but, that wasn't the question, it was about putting H1 wheels on an H2. why someone would want to do that, i don't know, considering the cost of most H1 stock rims.
Old 10-03-2007 | 11:55 AM
h2dan's Avatar
i had a customer who was gonna sell me his stockies for 400. with new 36" tires,thats why i'd go with h1's
Old 12-13-2007 | 10:00 PM
h2dan,
Send me his number. I'll buy them. LOL I have seen H1s with H2 wheels but never the other way around. Aluminum or steel wheels? 16.5 or 17"? Let us know what happens.
BMoney5327
05-07-2012 08:36 AM
sdot425
09-14-2011 10:04 PM
hilljob26
09-26-2007 06:00 PM
diamondh2
01-12-2007 12:10 AM
thaidoggs
12-28-2006 07:26 AM
