h1 stalling
h1 stalling
1995 h1 stalls out. i've replaced the lift pump, all fluids, fuel filter, oil pressure switch, and oil pressure sensor. still stalls out and is hard to start back up. ran new gas in it, the lift pump does not show any power when i hook up a tester. any help would be great.
RE: h1 stalling
hello guys.i had the same issue.check the fuel pump sensor plug.is a 4 pin black plug just in the upper part of the pump.remove it, check the pins and clean them,and put it back.[>:]this connectors and the ones inside the truck are poor quality.[:@]
RE: h1 stalling
your hummer being a 95 has a non turbo engine. the injection pump is a mechanical one with no electronics. if it is stalling, it is because of a fuel issue or you are losing the power to you shut off solenoid on the top of the injection pump. how often does it stall? do you have to prime the fuel filter to get it started?
rtwash
12-13-2013 10:45 PM
rtwash
04-02-2008 03:36 PM
jameswhite
08-23-2006 10:15 PM
