G2 LED mount
I bought a 50 inch led bar off of e-bay for a hundred bucks. Then ordered the G2 mounts. I did not have to bend the brackets they worked just fine. I did go to the hardware store and buy two rubber washers to slide between the light and the mount. If you do not have a rivnut tool and want to install the rivnuts yourself with the nut and bolt method GO to the hardware store and purchase a grade 8 bolt. The one that they send is weak and bent. Also the mounting bolts I received were not long enough. I opted for some stainless steel and about a 1/2 inch longer.
Also if you go with the e-bay knock off light. Go buy some clear silicone and take the light apart and reseal it. They leak.
Circuitguy
10-28-2014 09:19 AM
H8MYX
12-09-2006 06:40 PM
