Front suspension question.
Old 10-01-2007, 11:34 AM
hilljob26's Avatar
Default RE: Front suspension question.
if you think about it,you are doing the same thing with the ready lift that you are already doing,the only difference is is that you have less of the bolt going in to raise the key
Old 10-01-2007, 12:04 PM
The only thing you benifit from a ready lift is the shock extensions. The stock torsion keys will give you the same amount of lift as the Readylift or theTrux kit.Your better off getting longer front shocks! Click here- http://cognitomotorsports.com/store/Hummer_H3.html or if money is no object clickhere- http://www.samcofabrication.com/
Cranking the torsion bars just gives you clearance for larger tires. Yourreducing the sag of your suspension travel so it's causing problems.
KB84
04-10-2012 12:45 PM
HawaiianH3
12-30-2011 10:22 PM
federicoiz
11-19-2011 04:08 AM
chrisdoubleu
03-03-2010 03:05 PM
iowalawhummer
04-03-2008 10:29 AM
Quick Reply: Front suspension question.
