Front side window dimension
Hi guys, are you able to help me to measure the size of the front side window? I need to install a "Mesh Side Window Curtain" (privacy) for my Hummer H3 but I am not so good with the "numbers".
i made screens for mine and could measure them and give you the NUMBERS. they are cut to fit the curved top of glass. you need to put in a test piece and trace the curve.
its more than the numbers you will have trouble with.
made right the will slide into one end,then slide into the other end, then up.
then you very carefully raise the glass. it moves FAST!!
if you want to hang a curtain over the glass,how to mount it? but size would not be critical.
hummerhack
12-17-2014 02:25 AM
imikeh
12-14-2009 05:10 PM
pcmommy
03-23-2007 03:53 PM
