Front Nose dive after T-Bar adjustment-Leveling Kits help?
I recently adjusted my H3 T-Bars about1,1/2 turns (1" lift). I have about a 1/4 inch gap between the bump stop and lower control arm. Wondering if folks that have done the 2" lift with the new T-Bar keys and shock spacers notice anymore nose diving when thye added the leveling kits. I would imagine that the bump stop is way away from the control arm with that much lift.Would the longer/better aftermarket shocks (Blisten/Contigo) helps in place of the OEM shocks with extensions.
I am looking at the leveling kit, but don't want to worsen the nose dip when stopping hard.
CMT
CMT
RE: Front Nose dive after T-Bar adjustment-Leveling Kits help?
Here is the two previous posts. I think Gunner_45 has answered your question. https://www.hummerforums.com/m_63915/tm.htm & https://www.hummerforums.com/m_80962/tm.htm
The only ways to correct nose dive is to extend the bump stops, higher rate torsion bars or stiffer shocks. The best way is to extend the bump stops.
You should install longer shocks if you raise front end by cranking TBs.
ORIGINAL: CMT1
Has anyone extended the factory bump stops? Who, what, where.
CMT
CMT
This picture is with it jacked up because that is the only way you can get them out. Ok the bolt is now down to 2 1/4 inch. I had to go to FastenAll to get "tap" bolts today so I can squeeze it a little more. These are threaded all the way to the head. Total two-tone rubber baby buggy bumper jounce stop is 3 1/8 now. Seems to be important to recess the bolt. Im all the way to even with the turned down groove on the outside of the stock one. The new one I took it down half way. Anymore it may pull thru.
[IMG]local://upfiles/1095/C8A9430205F448BD9B8FDDB6F478AB51.jpg[/IMG]
[IMG]local://upfiles/1095/C77D5BD5A30543E2A31B961F67097BDD.jpg[/IMG]
[IMG]local://upfiles/1095/CD10589116D64C77AA0D9442DDDB8663.jpg[/IMG]
ORIGINAL: 07 HUMMER H3
go with a leveling kit it takes stress off the bar and you get a better ride.
Compare the two keys factory and the new ones you will see a big difference
MattN
02-08-2013 04:45 PM
HawaiianH3
12-30-2011 10:22 PM
fishin301
03-28-2010 08:31 AM
solarflare
04-21-2008 08:01 PM
aetherH3
38
12-13-2006 10:35 PM
