Front end squeaking
Old 06-07-2008 | 07:25 PM
cyp10's Avatar
Default Front end squeaking
I am assuming I need some lube on the front end. Whenever I am driving I have a squeak on the front end whenever the truck bounces up and down. Anyone else had this problem? Anybody know where this squeak may be coming from and where to apply the lube? Thanks.
Old 06-07-2008 | 08:39 PM
solarflare's Avatar
Default RE: Front end squeaking
my shocks squeaked on my 3.....it was really annoying....
Old 06-08-2008 | 12:15 AM
rhill20's Avatar
No squeaks here. First guess would be a lube job as mentioned. Second, have you checked to make sure that you don't have anything rubbing?
Old 06-08-2008 | 10:55 AM
cyp10's Avatar
thats what i think it might be. any remedy?
Old 06-08-2008 | 08:48 PM
RealJeep's Avatar
Lube job? There's nothing user servicable under the H3 for you to lube. The best you can do is get a can of WD-40 and soak down anything rusty under the truck. Pay attention to sway arm bushings and other rusty parts thatrub each other. WD-40 is non residual and won't pick up a bunch of dirt so don't worry about it, just keep it off your rotors!If and when the squeak stops you can reapply as needed or do a repair if you find a worn bushing or part.
Cbenn17
01-12-2014 08:20 PM
MattN
02-08-2013 05:45 PM
quadblaster240
12-19-2009 04:50 PM
brandon4589
11-25-2007 03:25 PM
buzzwohl
09-29-2007 09:27 PM
