Front differential case compatibility
Hello again, I am looking for the front case I spun the pinion bearing and need a new one.. Not as much fun as gearnading in on the trail but still sucks as bad. My question is are they the same if its 9.25 ifs or different to the hummer below is what I found at Randy's ring.. So when looking used would any case work or only hummers?????
PS putting in 4.88s already bought so just need case not owrried about gears
http://www.ringpinion.com/DiffDetail...&DriveType=4WD
well I putting in the 4.88s and I can use the carrier out of my H so I am only worried about the CASE itself is there anything different on the Hs like ribs for heat or something because its AWD instead of part time like most on that list thats in the link I posted
I have 2000 suburban 3/4 ton 4x4 and a 2004 H2. The front diff in the Sub is just like the one in the 2500HD pickups, I just did a swap to a 4.10 front diff. After looking around under the H2, the front diff is different. The H2 has a mount which attaches it to the crossmember below it, the standard 3/4 ton diff does not have that style mount. I believe you will have to go with an H2 case.
samer0214
18
03-07-2012 09:26 AM
BowTieGuy
01-17-2011 08:29 PM
cmj917
09-28-2009 07:56 PM
Nxsov180db
04-30-2008 09:55 PM
Nxsov180db
04-30-2008 09:37 PM
