factory alarm question
Old 09-16-2009 | 08:45 PM
Chris 07 H3's Avatar
Default factory alarm question
How do I turn the alarm chirp on and off . The key fob locks all doors and the system arms , lights flash but no chirp. I have looked all through the owners manual but I didn't find anything.
Old 09-16-2009 | 11:02 PM
stonemiser's Avatar
Good question. I'd like to know also. I've noticed that on my wife's H3. I have a hell of a time knowing if I armed it or not. Not sure if it has that ability or not.
Old 09-16-2009 | 11:16 PM
Hummer Guy's Avatar
I'm doing this off memory...but...
On the key fob, hold down both the lock and unlock buttons while you have the door open. "RFA #" will show up on the driver info screen. Hold the reset-odometer stick until it changes numbers. There are 4 numbers, and I don't remember which one is which, but #1 is silent for lock and unlock.
Cheers!
Old 09-16-2009 | 11:39 PM
White08H3's Avatar
It's definitely in the manual, but I can't remember which section off the top of my head. If I remember correctly #1 has no chirp when locking doors and unlocking doors and I think #2 chirps when you lock the doors, but does not chirp when unlocking doors. I could be wrong on that though, its been a while since I set mine...
Old 09-17-2009 | 09:28 AM
RKSmith163's Avatar
The following is in your Manual.
Remote Keyless Entry (RKE) Feedback
This feature allows you to program the Remote
Keyless Entry (RKE) feedback to a preferred setting.
To set your choice for this feature:
1. With the engine off, turn the key to LOCK/OFF.
Do not remove the key from the ignition.
2. Press and hold the lock and unlock buttons on the
RKE transmitter at the same time. Hold both
buttons until the DIC display shows the current RKE
feedback mode
3. To view the next available mode, press and hold
the reset stem until the mode appears. Release
the reset stem and press and hold again to view the
next mode.
4. Once the desired mode is shown on the DIC
display, briefly press the reset stem to set your
choice. The DIC display then clears.
The following are the available modes:
RFA 1 (default): This mode flashes the parking lamps
when you press the lock or unlock buttons on the
RKE transmitter.
RFA 2: This mode flashes the parking lamps and
sounds the horn when you press the lock button on the
RKE transmitter. This mode also flashes the parking
lamps when you press the unlock button on the
RKE transmitter.
RFA 3: This mode flashes the parking lamps and
sounds the horn when you press the lock or unlock
buttons on the RKE transmitter.
RFA 4: This mode disables RKE feedback. There will
be no feedback when you press the lock or unlock
Old 09-17-2009 | 08:09 PM
Chameleon's Avatar
Thanks for that info.
Reading that reinforces my thoughts of how clever these auto engineers are, each of our HUMMERS come with a DIC of it's own.
Old 09-18-2009 | 05:52 PM
Thank you that was what I needed to know .
Old 09-30-2009 | 10:46 PM
c70079's Avatar
I changed mine to that setting to get it to chrip, but my bad girl just wont sing lol anyone know any reason why it wont?
Old 10-01-2009 | 12:04 AM
robschmit's Avatar
Ok, seriously though, there's no option for chirp, but there is for "horn", right?
Old 10-01-2009 | 09:58 AM
White08H3's Avatar
Oh I see you want it to chirp like the aftermarket alarms do? Instead of the horn blasting? I don't believe there is an option for that unless you had an aftermarket alarm (like a viper or ultra or something)
Gomer
04-19-2013 07:43 PM
justin67
12-18-2010 02:12 PM
Nick119
30
04-12-2010 09:03 PM
theboss
03-13-2010 10:34 AM
lucky19942001
02-05-2008 08:21 PM
