Engine cuts out
Old 12-17-2008 | 03:40 PM
racegun's Avatar
Default Engine cuts out
When I am traveling around 52mph my engine starts to cut out until I get to about 55mph. It only does this when I am travelingsteady at around 52mph. It never does it when accelerating thru 50-55mph. Any thoughts?
Old 12-18-2008 | 09:57 AM
calif phil's Avatar
Default RE: Engine cuts out
Sounds like a miss fire. Have you checked the spark plugs and or wires, a fuel filter and some quality injector cleaner might not be a bad idea as well. I use Amsoil P.I. or Chevron Techron cleaner in mine.
Old 12-18-2008 | 01:51 PM
racegun's Avatar
I have tried injector cleaner and a new fuel filter and it still does it. I'll check the others later. Thanks
Old 01-20-2009 | 03:07 PM
racegun's Avatar
I pulled the spark plugs and they are fine. Ran some techron fuel cleaner thru it and replaced the spark plug wires and it still does it!!!!
Help please?????????????????????????????
Old 01-21-2009 | 10:05 AM
calif phil's Avatar
Could it be your torque converter going into lockup? Try and lightly apply the brake pedal just enough to make the brake lights come on at the speed you notice the misfire. That will disengage the lock up converter. If the problem goes away then you know it's just the converter going into lockup and nothing to worry about. If it is missing you should have a misfire code stored in the ECM and getting the truck scanned will point you to what cylinder is the culprit.
Old 01-26-2009 | 01:44 PM
racegun's Avatar
Not the torque coverter. I'll take it in to have it scanned.
Cashville
12-06-2013 07:56 AM
bigmoe1315
02-08-2011 10:54 PM
bigmoe1315
10-06-2010 11:03 PM
4U2NV
06-15-2010 01:34 AM
Ken06H3
11-22-2006 10:38 PM
