Engine bay to interior wiring
So on the week end I finally installed an LED light bar on the front of my H3 (photos to come), wired everything up, including correct relays and fuses, made it look like factory wiring in the engine bay.
Now here comes my problem:
I could not find any way of running a wire from the engine bay into the interior of my H3 so I could mount a switch on the dash
Where is the best spot to run a wire?? Is there a provision somewhere??
Any help with photos will be greatly appreciated.
Will grab some photos of my newly installed light bar soon.
I have temporarily wired the light bar to the high beam head light wiring to trigger the relay, as such activating the light bar when the high beams are turned on, this is however illegal here and it needs to be run through a separate switch to pass the annual road worthy inspection. Doing a lot of night driving at the moment and as such needed this bar to work ASAP.
above your left foot,(no clutch) there is a hole in one layer of thr 2 layer firewall. i drilled thru there and used a hole punch to make it about 1 inch for any future wires. i ran wires thru hose and packed sticky putty around it.
Since I had to run CB, Lighting and "other" wires I used a large Unibit (step drill) and a Daystar Firewall grommet (KU20040BK). Then some heat shrink tape. I can modify the size of the opening if/when I need to run more wires. We wheel our stuff like you do and it is water tight! No "rigged" stuff here.
DayStar KU20040BK Firewall Boot | eBay
Wire Grommet and Boot - Daystar - YouTube
Will check that spot out, mine has no clutch it's an auto.
A photo would be worth a thousand words.
CB wiring may be next as well
the putty i rigged up is stuff phone/electrical guys use for water tite plugging. ez to change
you cant miss the hole, i guess u missed this!!
use that hole as a guide and u wont drill thru the intake or motor or anything important
AmericanCarCraft
05-15-2013 08:24 AM
mstnangsherry
11-11-2010 12:18 PM
