ECU Tune for better mpg???
Old 09-07-2010, 04:46 PM
bosch's Avatar
Default thanks for the info
which model are you using and do the programs come for just this engine size or hummer ,or do you buy it preloaded for just the hummer. thanks for the help ..mike
Old 09-07-2010, 06:39 PM
You would get one that is for that H2 drive line with a 6.0 v8 application in it, they also will work on a few other GM models but you can only use it in 1 vehicle at a time due to the licensing. J
Old 09-07-2010, 06:43 PM
If it interests you I can get you the same one I used if you would like. I can price it and call you, if you PM me your #.. J
Old 09-07-2010, 07:09 PM
H2 Jay's Avatar
I have been eyeing up something simular. Problem im finding is im UK based. Octane of fuel is higher here..Lowest is 95 and it goes upto 99. From what iv read, the base maps have an octane rating of 93 tops in the US. Not to sure how it would react.
Old 09-07-2010, 07:51 PM
bosch's Avatar
Default thanks for the help , found one on e bay
thanks for the help , found a couple on ebay for 369.00 will give it a try .
will have to wait till the bills are lower to buy it , just bought a roof rack .thanks again ..mike
Old 09-08-2010, 06:28 PM
No problem.. J
Old 09-08-2010, 06:32 PM
92/93 octane is recommended/required with the most powerful standard maps. It is also the highest octane available at most fuel stations here stateside. Otherwise you would need to look for race fuel or av gas here..
You should be fine with 95 octane as long as it is not leaded fuel. I woulod steer away from the 99 unless you were going to go all out custom & add boost too..
So I wouldnt worry about 95 octane & running the premium mapping. It would actually be a little safer.. J
dowork
04-24-2021 10:21 AM
luda81
12-26-2009 08:09 AM
D VADER
16
07-09-2008 03:36 PM
geeggee
03-24-2008 10:36 PM
brandon4589
01-06-2008 02:00 AM
Quick Reply: ECU Tune for better mpg???
