Drop in RPM while stopping?
While my H3 hasn't had that idle fluctuation issue, my '06 Cobalt SS did. The dealer replaced the barometric pressure sensor under warranty, which did nothing . Ultimately, a PCM reflash got rid of the issue entirely.
One possiblity may be with the IAC, if your vehicle only does it when you are at an idle, then that eliminates several players in the game. A vacuum leak will cause a high idle, not stall the engine. If it's a fluctuation in RPMs at idle and no other time then I would be inclined to have your IAC scoped by a dealer to make sure it's working properly. Sensors sure can cause a lot of havoc!
Well, all that is fine and dandy, but at the same time my lights in the car will dim with the decrease in RPM's. The vehicles headlights also dim as well. The RPM's drop dramatically, and then jump back up. Sometimes, the engine will also fluctuate in RPM's by dropping and rising, and doing that a couple times before settling at it's normal mark.
Ultimately, if your first answer wasn't the right answer to this problem.. Could there possibly be another issue we might be overlooking?
Thanks for your time, Doc.
-Stavros
-Stavros
I went for a road test today with the shop foreman to check out my 4 wheel lock sticking in the lock position. That needs to be fixed, but that another story.
I asked about my h3 feeling like it wants to stall and light dimming on stop. All he really said it that it is NOT normal and the first though he has is a alternator that is not working properly. Definetley something in the ignition/charging system so he says. I am not going to explore it any more as of now, as it is not stalling out. I have a big enough bill coming to me next week, fixing the transfer case.
Good luck all. Please post if anyone finds the cause.
EVILKING
02-12-2015 06:49 AM
downway69
33
04-22-2011 03:49 AM
