Driver side door open/close sensor failing.
Hello everyone,
I ran my H3 through the power wash today and now it thinks my driver side door is open when it isnt. I narrowed it down to the driver side door because when i lock the doors only the driver side instantly unlocks. If i push the sensor in with my finger it still thinks the door is open. Has anyone else had any issues with the door sensors failing? I tried disconnecting the battery for 5 min and reconnecting. Didnt fix it. I really doubt the power wash got it wet but i could be wrong. Any suggestions would be greatly appreciated.
You can unscrew the switch from the body with a torx head screwdriver. Pull the rubber boot out of the body and there is a simple plug on the back that you can check for moisture or corrosion. I had the same problem whenever the vehicle got wet. I cleaned my switch but the problem returned a few days later. I don't remember why I did it but I ended up swapping the drivers door switch and tailgate switch which solved the problem.
gmpartshouseusa.com It is called a jamb switch and it will cost you $6.07. It is easily removed by taking out 1 torx head screw. I replaced the one on my rear door last night. It seems to get wet and fail. This time I put NO-OX on the connector side and put silicon over the 4 small slits on the switch side. The same switch fits all 5 doors.
Welcome to the club. I have had 3 differnet jamb switchs replaced at the dealer under warranty. The head HUMMER tech (when it was a HUMMER dealer) use to keep 5 or 6 of them in his tool box beacuse he got sick of walking to the parts counter so often.
pauly1052
06-27-2015 04:51 PM
mcioci
11-02-2013 08:53 AM
FurbiesAndBeans
06-09-2010 10:58 AM
khelms_98
12-25-2006 04:38 PM
