Door Panel Removal
You should have one Torx bit screw behind the door latch, and two on the door pull iteslf, behind a removable face panel. Start at the base and pulled the "pop" catches free, working your way up until the door panel can lift out of the window track. It is best to do this with the window down as to not scratch anything accidentally. The door latch and lock cables can be disconected via rotating them for removal. No tool needed here.
I just replaced my wife's mirror on her passenger side, it was pretty easy. pannel comes off and on with out much of a hich. Also, the dust seal uses an adhesivie that is reuseable. Not alot of work for the money saved.
aaronballard0033
07-15-2012 11:51 AM
hman969
05-12-2008 03:13 AM
