Door Handle Loose...
If you open the rear door, on the jamb of the actual door right near the door handle is a rubber plug that can be removed. It is black and the size of a fifty cent piece (remember them?).
Remove this plug and you will be able to get to screw holding door handle.
Hopefully it is just loose and needs tightening.
This is a clean job and relatively easy
Good luck
Good luck
Probably new handle which you can access thru the jack access panel. The plastic in the end cap has probably broken. If you wait it will completely come apart and you will have to open it from inside the access panel.
I get the feeling that some are talking about a rear DOOR, left or right, and others about the rear gate that the spare tire hangs on.
How to open that gate from the inside was discussed as i recall, a year ago, with no answer from anyone.
I followed that thread and it got scary. if you mess in there and the electric unlock gets screwed up, so far,noone knows how to open the gate. a torch maybe!
If someone knows how,lets hear it now.
