Disconnects
Disconnects
Sry guys about all the questions but what are ur thoughts about quick disconnects. I searched the forum but I guess the question is unless ur doing serious crawling are they necessary and will they shorten the life of any other parts.
I assume you are talking about sway bar disconnects. Where would you be using the "quick disconnects"? Front or Rear?
In the front they are completly usless. The amount of "droop" you would gain will be less than 1" depending on where your t-bars are now. Extended travel shocks will allow the "extra" less than 1" in droop.
In the rear, I have seen a marked difference in the articulation both "stuff" and "droop". Although, I am not one for disconnecting them due to the Off Camber hillsides and such we encounter. I take rollover stability over a bit of articualtion anyday. But that might just be me!
paulmar
05-21-2009 08:46 PM
