Dead Catalytic Converter - Possible replacements?
Hello,
I just threw a P0430 code and apparently the passenger side Catalytic converter has choked.
Does anyone have any experience buying aftermarket replacements?
I'm looking at Magnaflow and they offer two options. I believe one is CARB legal and one is not.
See here for details:
https://www.carid.com/2008-hummer-h2...B%5D=MagnaFlow
Any input, thoughts?
Quick update. With the dealer wanting $2100 for a factory replacement and after speaking with a Magnaflow rep I went ahead and picked up part # 49679. It's an OEM direct replacement and by design (2 pieces) it should be relatively easy to put in as opposed to wiggling in the large one piece OEM exhaust. $753 shipped. ~$1300 savings.
I think you made the right choice. I think when i cross that bridge- im dropping in headers, pipes and mufflers and skipping the cats. No inspection where i live so nobody will be any wiser. I had an old s10 and we put straight pipes in and it was loud! I bet the h2 would sound great!
Let us know how it all goes together!
I have these:
https://www.afcodynapro.com/DYNATECH/895760119
paired with this:
https://www.afcodynapro.com/DYNATECH/2120267642
No complaints so far
(blackbear remap, and Borla backbox)
paired with this:
I have these:
paired with this:
paired with this:
I actually saw those cats during my search. Looks like a decent setup. Glad to hear there haven't been any problems. The dealer tried telling me that with anything other than factory parts I was going to have problems. This is only true to a point and the Magnaflow pieces look to be pretty good quality.
Looks like the 2008 and 2005 models have different arrangements, I did the job myself with Magnaflow Semi-Universal CATS but it involved cutting, aligning and welding, quite some effort but it worked.
Anyway here are some of the key points:-
Good luck with the new CATs.
- The manifold nuts can be very tricky, it took a high power air tool, lots of penetrating oil and patience.
- Take the opportunity to change the lambda sensors at the same time, buy a good extractor tool and tap to clean up the threads.
- Be sure to break-in the CATs, dont just drive-off. Read this procedure which is worth doing at least twice allowing the endgine to completely cool down in between. Here is
- Be sure to break-in the CATs, dont just drive-off. Read this procedure which is worth doing at least twice allowing the endgine to completely cool down in between. Here is a video which is well worth watching.
hummer_04
07-12-2007 12:21 AM
