De-badging the H3?
Has anyone here removed the H3 badges from there truck? Im not much of a fan of badges and I think they have a cleaner look de-badged ... just wondering is there just double sided taped on or if they have a nasty hole in the panel and clip in as well as double sided tape ... ?
Just more info for you
When you pull the fishing line trough the back of the badge attached to the truck, it slices through the foam acrylic tape and effectively takes the sticky side that was attached to the truck from the sticky side that is attached to the back of the emblem. it cuts through the foam. Hope I explained that well enough ?
I have used a mild solvent and it loosens the acrylic adhesive just enough for you to pry the emblem off. This allow you to have the acrylic tape in good enough shape to reattach later on.
I have done this about twenty times on several vehicles and it has worked each and every time.
