Custom Off-Road Trailer for SALE
Old 05-05-2011 | 09:46 PM
nac51's Avatar
Default Custom Off-Road Trailer for SALE
I designed and built this Off-Road trailer to be a multitasking type trailer from hauling firewood to carrying essential camp gear, goods and certain ATV’s with wheel width less than 44”. Easily adaptable to accept a Car/Trailer Top Tent for convenient camping anywhere you may be and / or Surf Racks. Approx. 2300 lb capacity. I used this trailer on a test run to Ohio and back fully loaded with hunting gear twice this season. It worked PERFECTLY, UNFORTUNATELY I have to sell it as I need the cash.
Features include:
• HEAVY DUTY Frame: 2”x3” Tubular Construction. Primed w/FLAT
Black Paint on rails, inside box & deck. Outer sides of Side are a
Charcoal Gray Metallic.
• Box Frame: 44” wide X 5.6’ long Box Frame with steel floor. Also has
a 2” rear receiver.
• Deck: Extended tongue for easy towing backing and extra capacity.
Diamond Plate fore deck designed for additional space to
accommodate a cooler (Cooler Tie Down Straps Included), Tongue
Box with space to spare. Tie down loops on each side for auxiliary
fastening.
• 18" High Diamond Plate Sides with rear tail gate. Custom T/G clamp
guards prevent unintentional dis-engagement.
• 3500lb Axel and Springs with easy Grease Hubs. Shackles can be
mounted above the axel for an additional 3 to 4” of height.
• Custom Cover: Military Waterproof Fabric used for the custom
cover. (Tan/Camel in color).
• ALL Stainless Hardware.
• Stainless & Locking Hitch Pin.
• Stainless & Locking Receiver Pin.
• Inter-changeable Hitch Design: 2” Ball Hitch included. Can be
removed to accept any 2” articulating off-road hitch.
• NEW Fire extinguisher
• NEW Jerry Can GAS (Metal, Never filled) 5 US Gallon. With Secure
Metal Buckle Strap with Lock.
• NEW Jerry Can Water (Geeen Plastic/ Military Issue, Never filled)
With Secure Metal Buckle Strap with Lock.
• NEW Reese 48” Farm Jack: Never used. Custom Mount on Spare
Tire Carrier and easily removed/adjusted. Mount is removable &
adjustable in height and can be utilized for other purposes.
• NEW Spade Shovel mounted on Left Fender with custom mounting
brackets with lock for security.
• NEW Fiskars Axe mounted on Right Fender with custom mounting
• Tailgate opens and retained via chain with plastic cover. (2)
Custom Tailgate closures (clamps) with hitchpins to keep
clamps from opening on the trail.
• Spare Tire: 33” x 10.50” x 15” used with approx. 1/4” to 3/16” of
tread left.
• Tires: 33” x 10.50” x 15” used with approx. 1/4” to 3/16” of tread
left. (All were take off’s from my Jeep and have never been flat.
(NO PLUGS or Repairs). Larger Tires up to 35” x 12.50” will fit
within fender wells, with the removal of wheel spacers.
Shackles may have to be repositioned to the top of the axel
(easily done).
• Wheels: (including Spare) Steel 15” x 8” Jeep Wheels with a 5 x 4.5
lug pattern. I believe the 5 hole pattern will work for Ford
Wheels as well. (You may want to verify if necessary).
• Wheel Spacers: I added 1.5” Billet Aluminum Wheel Spacers that
can be removed should larger/wider tires and wider wheels be
desired.
• Custom Waterproof LED lighting include: Brake/Turn Lights:
(2) 4” Round Clear Lens RED LED’s.
Turn Signals: (2) 2” Round Clear Lens RED LED’s.
SIDE Running Lights: (2) 2” Round Clear Lens AMBER LED’s.
REAR Running Lights: (under Tailgate) (4) 2” Round Clear Lens
RED LED’s. ALL LED Lights are “Flush Fit” with Rubber Grommets.
ALL Wiring is professionally soldered, shrink tube wrapped and
sealed with a coating of liquid Electrical Tape for years of
service.
• Heavy Duty Swing down Jack: Bulldog Brand with easy ergonomically
friendly crank handle.
Asking: $3,500 as shown above. Negotiable.
BTW, I am planning on a brand new paint job in Gloss Black Epoxy to be completed over Memorial Day Weekend.
Have numerous pictures if interested. thanks
Nick
Attached Thumbnails Custom Off-Road Trailer for SALE-left-front-view-cover-00000.jpg   Custom Off-Road Trailer for SALE-left-rear-view-00001.jpg   Custom Off-Road Trailer for SALE-rear-rt-side-cover-00002.jpg   Custom Off-Road Trailer for SALE-rt-side-close-up-00004.jpg   Custom Off-Road Trailer for SALE-tailgate-led-red-running-lights-spare-tire-00003.jpg
Old 05-06-2011 | 12:31 PM
Draketh's Avatar
That thing is pretty cool and looks to have exceptional craftsmanship. I don't need it, but if I did I'd buy it.
Good luck selling something with jeep plastered all over it on a hummer forum.
carid
12-12-2014 07:56 AM
Travis Stillwell
05-01-2014 07:04 AM
Matt9509
05-01-2013 07:27 PM
gallf1
07-02-2012 04:34 PM
kauaineb
09-09-2011 11:52 PM
