Coolant temperature gauge failure
Old 08-09-2015 | 01:54 PM
Hummerrican's Avatar
Default Coolant temperature gauge failure
Yesterday the coolant temperature sending unit or the coolant temp gauge stop working properly. The indicator reading is 260F and over been out range. The issue is the engine isn't hot. Leave it overnight to cool down. When I turn off the switch, the gauge don't return to 0F. In the morning with the engine completely cool the reading is 260F.
Is this a common issue on H2's?
Where can I buy this new temp gauge?
Old 08-09-2015 | 07:35 PM
liveinxs's Avatar
Banned
It could be a bad stepper motor, you could replace it, hit youtube up, plenty of videos..
Or if you think you can't handle, you could just buy a whole new cluster, about 300.00, cause if one gauge goes, the others aren't too far away, from crapping out..
If you can't afford that, just buy a autometer gauge, about 60.00..
I wouldn't run without a gauge, if you run too hot, you will kill the motor...
Old 08-10-2015 | 10:23 AM
calif phil's Avatar
Mine temp gauge is doing the same. I think I will replace the stepper motor.
Old 08-10-2015 | 11:01 AM
tharber's Avatar
There are many companies out there that will fix this for you. I have 2 gauges out as well as a few bulbs. Most are $125 to $175 to repair all gauges and lights, plus shipping. Its a common GM issue, search google for GM gauge cluster repair.
TH
Old 08-10-2015 | 07:28 PM
liveinxs's Avatar
Banned
Plus its an excuse, to upgrade the dash with led lights and better graphics..
To get a really custom dash, you are looking at 350.00 off ebay..
Old 08-10-2015 | 07:33 PM
liveinxs's Avatar
Banned
In fact, here is a ebay listing for a modified dash
http://pages.ebay.com/motors/link/?n...839294&alt=web
Old 08-11-2015 | 09:30 AM
tharber's Avatar
The problem with a custom dash is the odometer and the altered odometer statement that will forever be attached to the car. That's taboo as far as dealers are concerned. if you send yours in to be repaired, it retains the original odometer.
TH
lilcmtz
07-17-2020 02:18 PM
Hungarianthor
01-09-2015 08:15 PM
Ronald M Abbott II
11-29-2013 06:34 AM
RealJeep
30
07-01-2011 10:24 AM
