Coolant level is fine, but says low?
Old 01-30-2008 | 07:23 AM
Herm's Avatar
Default Coolant level is fine, but says low?
Hi all, about a week or so ago a started a thread about the coolant level in my truck...after inspecting it, I added about 4 glasses of water..thats it.. but the warning light on the dash still says low coolant level...could this be the sensor, if so does anyone know where it is?? thanks.
Old 01-30-2008 | 08:45 AM
Muddydawg75's Avatar
Default RE: Coolant level is fine, but says low?
My bet is the sensor... they fault to ground so if you know it is full and can unplug it the light should go out and let you know it is a bad sensor. I would look on the top tank on the radiator.
Old 01-30-2008 | 10:05 AM
ronb's Avatar
uh oh.
read here and do the checks:
http://www.flashoffroad.com/Diesel/N...ackedBlock.htm
Old 01-30-2008 | 01:21 PM
Is your fluid level still good? I was curious about the outcome as I thought the block issue might be raising its ugly head again also. Good luck and let us know.
Old 01-31-2008 | 07:50 AM
Herm's Avatar
Does anyone know where the sensor is, I will replace today...hopefully that is it...I drove the truck yesterday and it ran fine..temp stayed right around normall on the gauge..
Old 01-31-2008 | 01:40 PM
Low coolant levelsensors are usually in the top tank of the radiator.... or the surge tank...
Personally I would unplug it first before buying one...
Old 01-31-2008 | 03:40 PM
Herm's Avatar
out of curiousity what would unpluging it do??
thanks in advance.
Old 01-31-2008 | 07:53 PM
in my experience low coolant level sensors usually short to ground... thus closing the circuit and giving you a light...
if you unplug it the circuit will be open...
I can't promise you that is how it works on the 1 though... I'm just trying to help... until someone that knows for sure comes along..
Old 01-31-2008 | 10:34 PM
vilim12's Avatar
i think muddy is right
Old 02-03-2008 | 10:13 AM
Herm's Avatar
Just to update, i unpluged the sensor and the light went off...now im in the market for a sensor
thanks for the advise
