Coolant leaking at record speed
Leaking while truck is not running. Looks to be coming from behind water pump pulley. Reservoirs level dropping 1 inch every 30 minutes. Is this a typical sign of the water pump seal going bad? Help!!!
I know this is a little late but FYI you can actually put tension on the belt with the belt tensioner while you break the bolts loose on the fan. Once you have removed them take the belt off then unbolt your fan. Works the same when you are tightening the fan bolts back up. You can use this trick on almost any car or truck with a serpentine belt.
alphahumdog
26
08-06-2014 08:58 AM
xanzion
07-13-2012 01:22 PM
