coolant leak
nothing is wet anywhere, no slime on the windows or windshield, nothing dripping underneath, nothing seems wet under the hood. It may sound stupid, but we noticed this when the heated seats where used, may have nothing to do with it, but its for sure anti freeze on the floor of the drivers side. nothing above that leaked down.
heater core and the a/c evaporator ,both are just small radiators
are located under the dash ,if the fluid is green its antifreeze.and the core will have to be replaced .some times the drain line on the evaporator will glog and you will get clear water on the pass side floor .from running the a/c , then you would clean the drain line out hope this helps mike
