Computer malfunction?
hi.
RE: HUMMER H3, 2008 LUXURY PACKAGE
we gave someone a jump start and immediately afterwards the interior courtesy lights would not go off unless dimmed manually by the switch. then a warning message appeared saying that the doors were open (which they were not). also the doors did not lock automatically after driving away. when we locked the doors manually all doors did lock but then the drivers side door lock sprung open after a few seconds. then later the courtesy lights would not go off at all even if we dimmed them with the switch. we live in northern cyprus with no proper hummer garage, only the company who sold us the vehicle who dont seem to know what the problem is and have merely ordered a new door sensor, dimmer unit and something to do with the door lock. the garage man tested the battery and it indicated "WEAK". also for a long time now the orange warning engine diagram remains on - indicating something to do with the fuel system although we dont seem to have a problem with it. HELP!!!!
Before you do ANYTHING else, disconnect the positive connector from the battery, wait 2 or 3 minutes then reconnect the positive connector to the battery post.
Also make sure that both the positive and negative connectors are good and tight on the posts.
See if anything has changed after doing that.
jfwiw
when you jump another car yours should be turned OFF. then its like you took the batt out.
the only thing then that could cause you a problem is if the other car put out very high volts on startup.
I avoid jump starts! I have a 2nd batt that can be easily unhooked if I need to jump another.
I don't want your volts in my hummer!
If you have another vehicle try swapping the battery before purchasing a new one.
If the swapped battery makes things right. Then you know it is the low output from the battery. A weak battery can wreak havoc with the sensitive computer systems.
qouting myself
this is so important.
you might get away with jumping someone but you risk damage to your electronics AND generator. the only safe way is to unhook your battery. never leave your car running since the other dead batt looks like a short and can blow a diode in your alt/gen. excess volts from the other can blow parts of your computers.
either of these can be your problem. the blown diode may let the gen charge but with crazy voltage/ripple that can drive computers nuts.
rheff, replace the battery,(think big, the stronger the battery, the better) and make sure the terminals are clean and tight(or cut them and install some stingers). Also, check your alternator output. GL
scared2buy
02-10-2012 03:25 PM
nastar
09-12-2008 01:54 PM
sitedrifter
08-07-2006 01:05 PM
