Clock reseting
Old 10-01-2007 | 02:08 PM
Gooch's Avatar
Default Clock reseting
Hello all.
Please help me.
I have a 2003 H2, and I have noticed that any time I turn off the truck and remove my key, the next time I start it up the time on the radio resets to 12 O'clock. Has any one ever experienced this, and what is the cause and fix?
Thanks in advance.
Old 10-01-2007 | 02:13 PM
Muddydawg75's Avatar
Default RE: Clock reseting
Do you have the stock radio in it?
Old 10-01-2007 | 02:15 PM
Gooch's Avatar
Yes, it is the stock radio w/ the Bose speakers
Old 10-01-2007 | 02:27 PM
Have you checked all of the radio fuses.... It seems to me the unswitched power wire has blown it's fuse...
Old 10-01-2007 | 02:48 PM
Gooch's Avatar
No, I will check those today. Are these fuses located with the usual fuses?
I also dug up some info on the net. Some Chevy Tahoes have the same issue..they contribute it to a coroded battery ground to engine wire. I will check and report back.
Thanks for your input.
Old 10-01-2007 | 03:01 PM
I'm not 100% positive because I just walked out to mine and I only see radio and radio amp....
Old 10-02-2007 | 06:11 AM
hilljob26's Avatar
i corroded battery cable can lead to several problems,it will cause coil packs to not get enough power and eventually cause a misfire..........put that on your maintence list
Old 10-02-2007 | 10:38 AM
Gooch's Avatar
Just figured I'd give every one an update on my issue.
It was the red cable that connects to the battery. I moved it a little (although it was actually connected tightly), and the car came back to life (after through the day progressing to not starting at all). I disconnected it and cleaned off the connector a little then re attached it. So far so good, but I'm going to have them replace the cable seeing that I couldnt get to the actual wires. They are too tightly wrapped up by the rubber protector.
Thanks again for all your help. This is a very responsive forum.
Old 10-02-2007 | 04:37 PM
Glad it worked out for you....
matlock339
11-18-2021 10:20 AM
Jules712
11-08-2016 12:03 PM
mghijm
07-17-2014 08:02 PM
CWC
05-31-2014 11:19 AM
JDub
11-15-2011 10:50 PM
