Chrome Hummer Fuel Door cover..weird question
Old 04-03-2013 | 01:03 AM
73 different sellers on FleaBay for a new one from $95-$215
h3 chrome fuel door | eBay
Old 04-03-2013 | 01:06 PM
lostsoul77's Avatar
Originally Posted by egroegart
There are literally hundreds of choices. Just google it.
Yeah but doesn't the OEM one which I have, require holes be drilled thru the fender? If so, then I can only replace it with the OEM one correct? I wish they made an OEM version with a lock.
Old 04-03-2013 | 01:33 PM
egroegart's Avatar
Here is a link to oem locking fuel doors. You can put any aftermarket fuel door that says it is for an H3 for your year. On some of them, yes you may have to drill a couple holes. Here is oem locking ones. Hummer H3 Billet Parts & Accessories | DefenderWorx - Camaro, Mustang, Ford Raptor, Corvette, Hummer, Truck, and SUV Billet Accessories
Old 07-16-2013 | 02:47 PM
lostsoul77's Avatar
Well I ended up breaking the plastic cap that is supposed to retract with the spring after trying to loosen it with PB Blaster; but it worked out as the door stays shut now but the spring is not protected by the plastic cap, not sure how it will hold up against the weather. I'll probably lube it with a bunch of grease or something. Thanks for the help all....
Old 07-17-2013 | 09:09 PM
Goat's Avatar
Got similar fuel door issues only involving the plastic cap/plunger which fits inside the plastic sleeve. Inner spring is intact and works properly. The plunger is "binding" inside the larger diameter outer sleeve and stays fully seated to the rear when it should be springing forward. Tried several different plastic friendly lubes & graphite. Both components surfaces which contact each other appear to be have no defects, burrs, etc.
One thought is to attempt polishing or removing a minute amount of material of the interior of the sleeve? Keeping in mind it needs to remain smooth for the plastic to plastic contact and remain gliding fluently.
Any thoughts or ideas would be greatly appreciated.
Old 07-18-2013 | 01:53 PM
lostsoul77's Avatar
Remove the cap/plunger like I did if you're not too worried about the spring rusting...the spring on mine still looks fine thru rain and car washes...
Old 07-18-2013 | 08:41 PM
Goat's Avatar
Used a low abrasive Dremel wheel and removed a small amount of the sleeve's inner diameter, applied some lithium white grease to the plunger & reassembled. Works like factory.
Jerseyguy
07-18-2012 10:16 PM
Davidh3
11-10-2011 05:51 PM
RenegadeMicro
11-08-2010 08:13 AM
fable123
06-09-2010 04:51 PM
xxterxx
08-27-2009 05:55 PM
