Changing brake pads tonight
Anybody do this yet? Anything special I should know about, or is it just the standard caliper bolt removal to get the pads off and on? I'm thinking it should only take about 15 to 20 minutes per wheel. Not sure if I'm going to do the rears today. They seem to have alot of pad left.
RE: Changing brake pads tonight
Interesting. So they aren't like thecar brakeswhere you remove one of the two caliperslider bolts and pull the caliper up, change the pads and then pull the caliper back down and put the slider bolt back in?
That's awesome. It sounds like it takes more time to take the tire off then it does to change the pads. You still have to slide a pair of plers in there to compress the pistons so that the pads will fit right?
Just did this last week. Very easy but here are some tips. You need to remove two very small clips that hold the pins in the caliper. Mine were located to the inside of the wheel well. Spray the retaining pins heavily with brake cleaner because they will be coated with brake dust and general grime.Tap the back side of the pin with a hammer to get it started. Then use a phillips head screw driver to hammer the pin the rest of the way out. REMOVE ONE PAD! Use two flat head screw drivers to press the pistons all the was in. Remember to remove the resevoir cap. Put a new pad in and then remove the other old pad. Use the two flat head screw drivers to press the other two pistons in. Insert the second new pad, replace the pins and retaining clips. You will also find a small spring like clip on the bottom of both calipers that is held in place with the lower retaining pin. Do not forget to reinstall it. The wear sensors on the pad go on the insde of each caliper. This is a very easy brake job. I had it done in less than a half hour.
That's great. Thanks for the advice. I have done brakes on probably 15 different cars in my life, all with caliper removal, and one that had a few frozen sliders (that was fun). This sounds the easiest by far. Is it the same procedure for front and back?
I'm done. It took me 90 minutes for all 4 wheels. The back one are standard single-piston calipers, so you do have to take the slider bolts off, but it takes 5 minutes, literally.
This brake job just justified me keeping this truck. I'm going to post pics and instructions for anybody who wants to do it on their own.
I haven't down the pads on the H3 but you need to be careful using the flathead screwdrivers on the pistons. If they slip you can tear the piston boot and have a leak. I used to remove the brake fluid res. cap and then you could push the calipers in easily and they would stay in. ( at least that it how it worked on mid year Corvettes )
