center dash vent removal
Old 01-24-2013 | 06:22 AM
dognut's Avatar
Default center dash vent removal
my center right side ac vent lovers fell apart. I got the part but how do you get to it? I know the center radio cover has to come off, but how is that attatched. 07 H3 thanks, tom south florida
Old 01-24-2013 | 07:26 AM
wfturner's Avatar
If you are speaking of the brushed aluminum cover. It is held in place by spring clips (only)
You must pull it straight out from the bottom first.
Put your fingers into the two holes which are the two charging ports at the bottom.
This gives you some where to grab. NO screwdriver around the edges !!!
Pull straight out and the bottom spring clips will detach.
Then grab both sides of the now loose cover and again pull straight back and the other clips
will detach. Be careful of the wiring harnesses attached to the cover.
They must be disconnected in order to entirely remove the cover.
Once it is removed, you will see the stereo unit and your two plastic vents
Good luck
Old 01-24-2013 | 07:51 AM
Exactly what wft said.
Also, If you are in a cold climate let the entire interior heat up before attempting the center dash trim removal. Less chance of breaking something.
Old 01-24-2013 | 05:45 PM
dognut's Avatar
got it done,piece of cake. thanks
Humanoid
Private 'Wanted' Classifieds
03-27-2021 02:23 AM
gmizell
20
12-15-2014 11:19 AM
tek6006
04-13-2011 05:52 AM
2006 H2
03-16-2009 11:33 AM
jstdoitt21
12-18-2007 04:46 PM
Quick Reply: center dash vent removal
