CB mounting location
Old 07-11-2008, 05:27 PM
SarGuy33's Avatar
Default RE: CB mounting location
I have two solutions to mount a full-size radio. Niether are CB's but the ideas should work no matter.
One is a scanner suctioned to the bottom of the windsheild. I added a couple of rubber feet to the bottom of the scanner so much of the radio's weight is on the dash. The suction cup is a HD one from RAM Mount
The second one is a VHF radio on a pedestal that bolts to the passenger seat frame. My goal was to have no holes drilled and no mods to the vehicle. This pedestal was pieced together from RAM components. RAM makes a seat mount specifically for the H3. I bought each peice one at a time to see how it would fit. If I was smarter, I prolly could have figured it out on paper first
I bought all my RAM stuff from GPS City in Nevada. Good prices and fast shipping. Google for web address.
[IMG]local://upfiles/2169/9CEB121B415C491C8FB0BAF820846AA3.jpg[/IMG]
[IMG]local://upfiles/2169/B3DC23B9A8844CDAB3DE5C4DEDF9FC35.jpg[/IMG]
Old 09-28-2008, 02:20 PM
Ghostrider's Avatar
I did the same antenna mount as Tinked. I found I wasnt getting a good ground though so I ran a wire to the ground of the wiper motor in the door. I also put a quick disconnect and I have a removable solution with about a 8+ mile range (out the back..about half that if they are in front of me)
As for the "75 compare to the typical cheap full size CB" comment...it should be exactly the same. All CB's no matter how expensive will transmit and receive at the same power rating. The extra cost is for the bells and whistles like noise canceling and built-in SWR meters. Bottom line, you'll get the same signal coming into a cheap CB as you will an expensive one. You will be better off spending your time and money picking a technically sound antenna setup.
Old 09-28-2008, 02:22 PM
Ghostrider's Avatar
Oh yeah... my CB is just under the drivers seat with just the mic coming up between the seat and console. I put an external speaker tucked up under the drivers side dash. You cant see a thing if you want to keep the stock look, not drill any holes and it works great.
Old 10-02-2008, 02:40 AM
General's Avatar
ORIGINAL: trev0006
I like the location Steve #1 posted.
I like it too, but with the sunroof, it's impossible.
Old 10-04-2008, 12:49 AM
BRad's Avatar
what is the best cb antenna to use and where is the best placce to mount it
Old 05-02-2014, 05:17 PM
e0308jr's Avatar
Where are you guys mounting the antenna ? and running the cable?
Old 05-02-2014, 10:00 PM
rsc's Avatar
rsc
rsc is offline
Running the handheld 75 and a couple firestick antennas. I use a 3' on the trail but hear a fair bit of noise I don't like and a 5' on the hwy that gets great, clear reception. I have a mirror mount setup on my grill guard and ran the cable through the firewall. For range, the antenna being on the front seems to be balanced out by the roof rack blocking some of the signal to the rear, especially with the shorter antenna.
Old 05-02-2014, 10:09 PM
skeeter's Avatar
I mounted mine on a metal strap attached to my spare tire carrier. It allows the antenna to be offset to clear the rear wiper.
Draketh
03-30-2011 08:51 AM
H8MYX
05-05-2007 02:43 AM
07HummerH3
04-12-2007 09:40 AM
hummer1
04-05-2007 05:59 PM
SlinkTMP
01-18-2007 06:40 PM
Quick Reply: CB mounting location
