Can someone Verify My dash dimmer questions?
Hey guys, I have my 2006 H3 at the dealer as we speak, I found that my dash gauges are not dimming at all when I roll the dimmer dial up or down, I see that my radio lights are dimming a bit though. I swear I thought the dash gauges would dim as stated in owners manual and I beleive thay have in the pass but not forsure.... Dealer tech is telling me theyre not suppose to dim? can someone answer this for me please? Thanks guys!!!!!
Mark
Mark
I'll try
I have an 07, but the vertical wheels on the dash is supposed to dim the lights
almost all the way to off, when you rotate the wheel down
Turning the wheel up should brighten the dash lights and then the wheel hits a detent and the dome light comes on in the cab
Hope that helps
Hope that helps
I have had this happen to me.
I was advised by someone here on the forum to disconnect the battery, both leads, touch them together, place back on the battery, so I tried it and it worked........for a little while, so I had the dimmer replaced.
shegodemona
01-19-2010 02:08 AM
hummerdad
09-07-2007 12:20 AM
