Can I integrate Bluetooth into a '06 H3 Monsoon system?
Hi this unit is unplug your vcim and plug his unit in it uses your speakers and mic. Here is a link http://www.costartech.com/pb/products/bluestar.html
"We dropped OnStar service"
did u have bluetooth b4?
did it stop working with onstar dropped??
i use bluetooth,factory, in my 2010 after pulling the onstar antenna and it is still ok.
i assume it is a separate item,as listed in the "spec sheet" for my h3.
if it dies when on* expires i will sue gm!!
blue should not need on*
tom
tom
tom
tom
Hi the gm bluetooth will keep working after you cancel onstar. Factory GM Bluetooth and onstar are in the same box the [vcim]. SedonaBoundH3 truck is a 2006 it never came with bluetooth so the bluestar 2010 unit will give him bluetooth in his truck using the factory mic and speakers without cutting wires or anything. You just unplug the 2 plugs on the vcim and plug them into the bluestar 2010 pair the phone with the unit. Then it uses the onstar buttons and steering wheel buttons to make calls or from the phone itself.
Very pricey
