Burnt antifreeze coolant smell?!?
Just bought my 2006 H3 3 weeks ago. This weekend when to check fluids in the truck and poured some water into both the windshield wiper plastic container and the plastic container right next to it (assumed its the coolant overflow container). Ever since then car does not overheat but when it run warm you can deff smell a burnt coolant smell when you stop and get out of the truck. Should I be concerned? Was the plastic container next to the windshield wiper fluid container the correct container to fell up with water? Thanks for all help on this just don't want to blow up my truck just 3 weeks into ownership I luv my H3 ..![Big Grin](https://www.hummerforums.com/forum/images/smilies/biggrin.gif)
![Cool](https://www.hummerforums.com/forum/images/smilies/cool.gif)
If you smell coolant there is likely a hairline fracture in the radiator. If it is small enough it may just be a fine mist that sprays out when the engine is hot and it will not create large puddles but will likely get worse over time. Keep an eye on levels if they are dropping this is the most likely problem and will require replacement of the radiator.
Hopefully you didn't fill both up adn looked at the side of the container to see there is a Cold level and Hot level. If you filled it, it will surely overflow.
That being said, check for cracks like those gents suggested.
Took it to my local ASE shop and there is a deff leak in radiator after pressure testing. Good thing I bought an extended warranty thru Costco right after I bought the car it only has 52+k on the clock. What a defective POS radiator these H3 have that being said I still luv the hell out of my H3...
Forsche
12-12-2011 02:51 PM
