BU cam always on?
BU cam always on?
Anyone with an '08 backup camera system been able to modify the system to keep it energized while in Drive as well as Reverse? I gave it a shot today without success. FYI,below is the schematic.
RE: BU cam always on?
I would like to do the same. Mine is wired to the back up lights. When you put it in drive the picture goes to snow!![:@] So you have to turn it off unless you're backing up! Good luck. I hope you get an answer.
ORIGINAL: veves
ground it if that works put a toggle switch
The camera/monitor are energized via the reverse switch circuitso tapping into that signal would probably do the trick. I'd heard the '09 might have on-demand rearview camera functionality so I figured they reconfigured the engagement to reverse and/or manual input (dash button or programming option) to allow the driver to select the mode.
Iplaced a jumper from hot to what appears to be the shifter energizer pin on the connector for the camera control module behind the dash but, no cigar. I tried a couple more combinations without any luck. The bu camera/monitor combo are only activated with the reverse switch at the shifter.
mtauseefsa
09-24-2010 01:53 PM
mountainbiker
07-02-2008 03:18 PM
Gunner_45
17
08-16-2007 06:51 AM
HummerGuy
07-02-2007 02:22 PM
