Braking issue
Braking issue
Recently, my H3 has been "chugging" (for lack of a better term) when I brake. Basically, when I press the brake, the H3 "chugs" as it declines in speed. It is very noticeable and happens any just about any speed. Anyone else have this problem, or know what it might be? For reference, I have an '07 and it just broke 100k miles. Thanks!
I just had to replace my rear rotors and pads for the same symptoms listed by the OP. One of my rear rotors actually had a rusty area on one surface where the pad was obviously not making contact which was causing the pulsation.
Many times the rotors aren't actually "warped", but rather brake pad material has been unevenly distributed on the surface of the rotor making the run-out excessive. In otherwords there are thick and thin spots when measuring with a micrometer which cause the pulsating brake pedal when stopping.
If not, your caliper may hang up on them causing uneven wear and cause the brakes to pulsate.
quadblaster240
10-16-2009 07:51 PM
xxterxx
06-28-2009 07:39 AM
