brake line replacement...
#22
take note... the fittings description on the online GM parts manual is not right as i decided to buy oem fittings.. i have the links below.. and they are all good and fits well
for the lines from the main reservoir to the BCM .. these are 5/16 lines.. and brake fittings are Inverted Flare Nuts, Zinc Plated, Steel, Male 1/2 in.-20 , 5/16 in. Fuel line, Set of 10 - http://www.summitracing.com/parts/aaf-all50140
Lines for the front left and right are 1/4 tube , and brake fittings on the BCM side thread size 9/16-18 in. Thread, Pair(http://www.summitracing.com/parts/aaf-all50119) and fittings on the front wheels are 7/16-24 thread Inverted 9/16-18 in. Thread (American Grease Stick Co. Steel Tube Nut - 10 Per Bag - 1/4" (7/16-24) Inverted BLF-13: Search no more for the best Brake Hardware - Universal at Advance Auto Parts)
rear lines 1/4 tube, BCM side brake fittings , and to the rear brake assembly bracket are all 9/16-18 in. Thread (American Grease Stick Co. Steel Tube Nut - 10 Per Bag - 1/4" (7/16-24) Inverted BLF-13: Search no more for the best Brake Hardware - Universal at Advance Auto Parts)
#24
agree phil.. i am glad i use these.... lines from advance auto.. with the coupon code.. it was worth every cent spent
1x25ft roll is enough for the front left and right lines...
this is what i used for the front lines : NiCopp Nickel/Copper Brake Line Tubing Coil, 1/4" x 25'
and from the brake reservoir to the BCM, i used NiCopp Nickel/Copper Brake Line Tubing Coil, 5/16" x 25'
ak47dennis
03-17-2015 10:57 AM
