Bouncy ride on 20s
Have you done anything else to it besides the tires & rims. sometimes when the front is raised to level it out people have had conditions like you describe, most add cognito front shocks & trailduty's longer bump stops. also what psi are your tires at?
As you lower the profile of your tire the sidewalls becomes shorter. Nearly all the tire flex comes from the sidewall. When it is shorter it reduces sidewall flex, thus the ride becomes firmer...unless your a$$ is dead!
Bought it with the rims on it. As far as I can tell there are no aftermarket alterations to the susspention. The tire pressure is 36-38 in rear and 34-35 up front. I am used to driving lowered cars so I understand there will be a stiller ride with the shorter side wall of the tires but this thing really bounces all over the place I.E. bad bump steer and rear bouncing alot. I am under the impression that heavier wheel/ tire combo needs a heavier shock to handle the added weight.
I'll get under it today and take a look at the end links and post back
The only suspension difference between standard and Adventure are the front and rear shock absorber part numbers. The springs remain the same between the two. It seems like the factory tweaked shock absorber specification to account for just the heavier 285 tires.
I guess the question when running an even heavier wheel/tire combo is how much more shock do you really need and what brand/model to choose to get there?
Most of the larger aftermarket wheels are very heavy. They may look cool but the extra weight is what auto enthusiasts call unsprung weight. To improve your car's handling also consider stiffer sway bars for flatter cornering and adjustable shock absorber that you can fine-tune to your liking.
jsbihn
03-11-2015 09:13 PM
hummahumma
07-13-2009 12:01 PM
psych0
27
06-06-2009 09:04 PM
