Bigger Tires and MPG
Old 10-31-2006 | 06:27 PM
backroads33's Avatar
Default Bigger Tires and MPG
I own an H3 and i cant decide on whether to go with 33s or 35s. i know there will be less of a MPG change if i get 33s, but i would love to have 35s. so if there isnt much more difference between 33s and 35s speeking in MPG then i would go 35s, but i dont know how the MPG will be affected. anyone?
Vehicles
-98 Ext. Cab Z71 with 6-inch lift and 38.5x14.5x15 TSL SX
-06 H3
Old 10-31-2006 | 08:10 PM
importkiller's Avatar
Default RE: Bigger Tires and MPG
35's will lower your mileage slightly. I only saw about 1-2 mpg change in mine after switching to the 35's, but I was also getting 10.5 mpg with the stock tires[:@]
Old 10-31-2006 | 08:42 PM
dilo2001gt's Avatar
That's only your special truck that GM made for you on a friday.
Old 10-31-2006 | 08:46 PM
BirdEye's Avatar
Newbie Question: Can I put 35's on my rig by simply replacing the 33's I got on there as OEM...or do I have to buy new wheels?
Old 10-31-2006 | 08:49 PM
dilo2001gt's Avatar
35 fit on oem rims
Old 10-31-2006 | 09:58 PM
cyp10's Avatar
i have 33" super swamper boggers and i can tell the difference in mpg. probably about 2 mpg. then again the boggers have a really agressive tread for mud.
Old 11-01-2006 | 12:45 AM
shortbus's Avatar
in most cases, bigger tires won't noticably effect your mileage. your speedo will be off, as will your odometer and everything else related to distance travelled. bigger tires take longer to make one full revolution, so although you may travel the same distance, your computer will think different. this whole thing about mileage and tire size is getting boring, it's not the tires as much as it is the computer. aggressive tread will increase your rolling resistance, therefore making mileage worse, but that change is minimal. you'll need to send more power to the axles to spin the heavier tires, again making a minimal change in gas mileage. still, with all of that, the biggest difference is that your computer is calibrated for a specific tire size. when you change that, your computer doesn't know it. unless the dealer can change it for you, you're stuck with the stock programming and you'll just have to deal with the fact that you need gas to drive, and your decisions on tires will have some impact on that.
Old 11-01-2006 | 01:03 AM
GHummer's Avatar
ORIGINAL: dilo2001gt
35 fit on oem rims
question - what is oem?
Old 11-01-2006 | 01:32 AM
fisherman119's Avatar
original equipment manufactured
Franky3030
03-17-2010 09:55 AM
supsam86
02-10-2010 08:21 PM
Niznac
12-21-2008 01:53 PM
RealJeep
05-27-2008 08:40 PM
jackk frost
03-03-2008 01:29 PM
