Best Battery Terminals for my H3?
Hello everyone,
I was wondering what is the best battery terminal replacement that you guys have used? I honestly think that the reason my car is stalling out is because of the terminals. I went to get my battery check out and they two different auto parts stores tested it and they gave it a thumbs up. I do get the code P0017, but I already ordered the Camshaft Solenoid replacement. Hopefully after I install that i can fix the problem.
best ive seen, i have brass like these.
you can cut part of the old ones with tin snips , drill a hole and bolt them on to these, ugly but solid!!
if you toss the clamp you can use the bolt to go thru the flat of the original drilled.
never use a clamp on copper stranded wire, it will creep and loosen.
I actually like and installed the spt53501/02 terminals(covers the terminals)
BTW, I took off the stinger plastic covers to show the connections:
