Battery, window & locks problem
Old 02-12-2007 | 04:21 PM
simian's Avatar
Default Battery, window & locks problem
OK I have a question.... I left my Sirius radio and TomTom turned on and it ran down my battery. I have the H3 a jump but then for about 1/2 a day the driver window would not go down and the electric locks would not work. Is this normal? or is there something wrong?
Old 02-12-2007 | 04:28 PM
Dennis's Avatar
Default RE: Battery, window & locks problem
Yes..The Computer has to resync with stuff
I'm assuming it's fine now..right?..If it happens again, disconnect the battery, both leads and touch the leads together for a few minutes then reconnect them to the battery starting with the positive lead first.
Old 02-12-2007 | 04:29 PM
Hummer Guy's Avatar
did you stop and start it again after the battery had recharged? A lot of systems under lower than normal power (dead battery) can do some strange things and set off codes. If it happens again on a full charge, I'd get it checked out....otherwise I wouldn't worry about it.
Old 02-12-2007 | 06:42 PM
jbnjc123's Avatar
Good advice Dennis. I guess this is a "normal" thing to happen. Maybe a Mod should put one of these threads at the top as a bulletin. Just a thought.
Old 02-12-2007 | 06:49 PM
jbnjc123's Avatar
Here is the link that explains what happened to me....sounds like the same thing.
https://www.hummerforums.com/m_39555/tm.htm
Old 02-12-2007 | 08:07 PM
simian's Avatar
Thanks guys, I was kind of thinking along the same lines, that it was some CPU thing. Good trick to know (touching the battery cables together) This problem lasted, maybe, 3-6 hours then all was good (It happened about a month ago but I have not really had time to post)
Thanks!
Alukavi
12-28-2020 10:22 AM
JensH2
12-14-2013 03:27 PM
h3andme
02-22-2011 08:08 PM
jhpulley
11-27-2010 01:21 AM
pcmommy
03-23-2007 04:53 PM
