Battery and charching system problem...HELP!
Old 12-19-2012 | 11:05 PM
h3carlos's Avatar
Default Battery and charching system problem...HELP!
I removed my battery to replace my alarm siren last night. Installed battery again, Turned on the truck and drove it into the garage. I noticed the radio was not working, checked the fuse and it was blown. Replaced it, and fixed the radio. This morning after about 15 min of driving, all dashboard lights came on, a bunch of "service" messages appeared and the service charging system message appeared. I was able to make it back home. I checked the battery charge and it was at 0. Charged it back up, took a test drive.....same problem. Any ideas???????
Old 12-20-2012 | 01:15 AM
Happy Hummer's Avatar
Possibly check to see if when your engine is running the value at the neg. pos. is approx 14-15v.
Also is the bat able to sustain a charge? Id check the volts across the battery when head lights are on. Should hold and not drop to much.
Chris
Old 12-20-2012 | 01:11 PM
h3carlos's Avatar
volts runnin at 14. w all lights and accesories on.....I changed the mega fuse and charging up the battery...lets see what happens
Old 12-20-2012 | 01:26 PM
Gr8 keep us posted...
Chris
Old 12-20-2012 | 02:06 PM
h3carlos's Avatar
seems to be runnin w/o a problem....repalced fuse, charged battery and took a 20 min drive....no issues. fingers crossed
Old 12-20-2012 | 05:04 PM
Cross your toes too! Lol!
Chris
Old 12-21-2012 | 07:38 AM
carloscrx101's Avatar
Check for crack terminal batery post I have same problem it was battery...good luck
Old 12-23-2012 | 02:46 PM
h3carlos's Avatar
That was it...mega fuse blew. All systems go!
Old 12-01-2016 | 11:09 PM
H307strong's Avatar
Hi all,
New member here. Where can I find the "Mega" fuse?
I have the same "Service charging System" Msg.
Old 12-02-2016 | 09:25 AM
Welcome to HF. In the future, please avoid resurrecting an OLD Threads, this one is 4 years old in a couple weeks. Better to post your question in a NEW Thread and just link this old one.
The Mega Fuse is at the top left corner of your fuse box between the + & - power terminals of the fuse panel. Name:  IMG_6376.jpg
It's a 125A like this one.
trxblack
01-14-2014 03:39 PM
garnaout
01-17-2012 02:04 PM
supsam86
03-25-2010 09:06 AM
simian
02-12-2007 08:07 PM
HummerGuy
09-08-2006 05:05 PM
