Auto trans failure
Auto trans failure
I've just had my trans go. It started to make a real whine today and slip into and out of gears, even when the car is in neutral it has a real whine.. If I stop the car for a few minutes and start it, then it's fine for about 2 minutes, then it comes back. It won't hold gears and eventually just looses all forward drive. The fluid was a little low- bottom of the cross hatches when hot, so I have filled it up.. But doesn't appear to have helped..
Has anyone has this, or have any ideas?? .. Off course I am just out of warantee too!!!
I would be happy to look into this for you with the last eight of your VIN. This will allow me to get a better understanding of when your warranty expired. I may also be able to set up a case for you with customer assistance. Please contact me privately with more information. Thank you in advance.
Tricia, GM Customer Service.
ozHummer; Please check your coolant. YES, I said coolant!
If it is a brownish color then you have a leak between the trans portion of the radiator and the engine coolant portion! Many, many people have had this happen and it's not a cheap fix. Search the forum for the threads on here. If I had the time I would do it for ya.
Thanks Tainter.. The dealership has since totally replaced the tranny as they admitted tat I had told them about the issue when the car was in warantee.. Interesting you mention the coolant - I will check to see if there has been a leak between them..
njhusker
11-04-2019 11:36 AM
greg260
01-27-2018 12:41 AM
SikFukinH3
01-29-2012 07:56 AM
