anyone else get stuck?
thanks feel little better, we dont normally get the kind of snow we got this week 3-5 feet. first time I got stuck I did make it about mile and a half in snow basically up to grill, didnt get stuck until I tried to make the last hill before my home. of course the last time I got it was in plowed snow not nearly as high but i think the ice may have gotten me there. the toyo tires mentioned on here by one of you guys, are they same size as stock?
If your running the stock tires, don't feel bad they suck in snow in my experience. I found that the all terrain tires are a nice upgrade to consider as far as snow handling. If your talking about fording through snow that's a different story. If you plan on doing some good mudding or something you will come into an issue with tire choice. Usually best tires for mud are worst for snow.
What I used (Dana 44) is about twice the strength of the stock H3 (aluminum housing AAM 7.63) diff. It's advantages besides strength are.
1. Selection of gear ratios that match what is available for the rear diff. for those who would like to gear down. (There are no lower gears available for the H3 stock front) This is good if you run oversized tires and feel underpowered.
2. Selection of lockers that could be used that are not available for the stock H3.
Check this out for an in depth discussion of the topic.
http://www.hummerxclub.com/forum/sea...aser&start=135
Honestly, I've come to the conclusion that the car or truck you are driving in the snow is a very minor piece of the equation. A Jeep, a Hummer, an FJ or whatever all come down to the same basic principal in snow: 4 tires trying to maintain traction. Your tires are immensely more important than the vehicle in my opinion, so I wouldn't go too hard on the Hummer.
Nope, never been stuck. There are limits to any vehicle. I saw a raised (I mean RAISED) F150 in town get stuck in a couple inches of snow because the driver figured he could do anything and din't realize the ice underneath the snow spun and spun and spun his tires.
I have had trouble a couple times in regular 4, but if I shift to 4lock I have no problem. I have been through a couple of severe storms.
I never tried low.
That is entirely possible if you have an 06 or early 07, the 4wheel lock shift fork was made out of plastic and alot of them have failed with varying symptoms. Go check out the Hummer X club for a very recent thread on that.
If you are running stock 32" tires, you already found out you have to lean on driving skill and experience, not 4 wheel drive.
