Any one install a remote oil filter on H2?
Old 06-06-2012 | 06:03 PM
Rusty_03's Avatar
Default Any one install a remote oil filter on H2?
Have been planning on installing a remote oil filter on my H2 mainly to install a larger filter.
Has anyone done this? What block adapter did you use?
MikeH
Old 06-06-2012 | 06:34 PM
LoJac963's Avatar
I asked this same question a while back with no responses. I'm looking to relocate the filter for better access. I've only found one kit specific to the H2 but I know the block off plates are engine specific so really the options should be limitless. I just need to confirm the threads on the block....
Old 06-06-2012 | 08:43 PM
honda400ex2003's Avatar
im curious as to why you want to move it for better access? it is right there facing up, its by far the easiest GM engine filter i have came across to this point.
maybe im spoiled, i can just about sit straight up while doing my oil change without a jack or anything under it. lol
just curious,
steve
Old 06-07-2012 | 05:22 PM
Rusty_03's Avatar
Relocation is secondary. I just don't like the itty-bitty filter.
MikeH
Old 06-07-2012 | 07:28 PM
LoJac963's Avatar
Well all I have owned is GM vehicles my entire life and I can definitely tell you it is NOT the easiest filter to access.
At the same time I never said it was hard, it is in an awkward spot. If the frame/skidplate isn't cutting your hand/wrist up then oil is dripping all over the place. I want to move it for simple convenience of making oil changes that much easier.
Old 06-07-2012 | 10:18 PM
a bigger filter would be nice, you could in fact run a bigger one on it if you wanted to. just get one thats the same diameter and run a longer one. I had a longer one on mine when i changed my oil last weekend. i took it off and put the correct one back on.
maybe im missing a skidplate or something, i didnt have anything blocking my plug or access to my filter. it is a bit tight on one side but i got it off and back on in a couple of minutes.
i was just curious, both are good enough reasons to move it if possible.
steve
H2zona
08-06-2018 07:31 PM
drtom
01-17-2011 10:23 PM
LGK
10-03-2010 05:09 PM
hummer07
11-18-2008 11:46 AM
Brandon07
40
07-27-2007 09:29 AM
