Another starting issue
Old 08-28-2007 | 12:56 PM
Herm's Avatar
Default Another starting issue
I thought I had this resolved, anyway after replacing the glow plug as I stated in my last post I was using this vehicle with no problems...I have not started it in about 2 weeks... went to start it yesterday and it just cranks no start with some white smoke coming out in the back??? any takers.??
Old 08-28-2007 | 01:12 PM
hmcoleap's Avatar
Default RE: Another starting issue
Do you hear your lift pump running when you turn the key to the ON position?
Old 08-29-2007 | 06:56 AM
Herm's Avatar
I swapped out the lift pump a month ago...its working fine...It did start yesterday, it took about 8 to 10 cranks of the motor...
Old 08-29-2007 | 09:01 AM
hmcoleap's Avatar
Make sure the lift pump is running anyways... I've seen a new lift pump fail in the first 2 weeks before (defect) -- make sure it is running, even if it is a relatively new part.
Or, it could be "turned off" for some other reason (e.g. faulty oil pressure sender)
Ryan Scott Serrano
01-26-2015 12:09 AM
Happy Hummer
08-10-2014 12:11 AM
baltogun831
12-17-2012 12:11 AM
cricket
03-13-2008 04:14 PM
BlackTiger
11-19-2006 02:32 PM
