Alpha and Rancho kit
I have an Alpha with cognito shocks and torsion bar crancked. My truck keeps rubbering when I turn the wheels. Any ideas?
Anyone know if its possible to install the 4" rancho lift kit on an Alpha 2008?
I talked with technicians from rancho website by phone, they told me its possible.
Anyone can confirm this? I dont believe the guy by phone, he just want to sell it.
Thank in advance.
Fragss
Thank in advance.
Fragss
RE: Alpha and Rancho kit
What tires are you running? 35s should fit. I am not into lifts but tryu the search function. This has been heavily discussed and I think the consensus was the the Rancho lift didn't work on the Alpha. Unless Rancho has come out with a kit for the Alpha I don't think it works. Some others will chime in shortly but try the search function.
I have the SAME thing going on, but i'm not rubbing on the control arm...my wheels are making contact with the fender liner! Not by much, but enough to make a super loud noise and cut my turning ability down quite a bit. Body lift? will a suspension lift solve my problem?
I had to cut the bottom spoiler, you can see the pics here:
https://www.hummerforums.com/m_137694/tm.htm
But keeps rubbering on the front, also the rims are scratched from inside.
The setup is 325/60 20
I lifted with torsion bars 3", same distance as rear.
I dont know what to do, I need some ideas, please help.
Thanks in advance
fragss
Thanks in advance
fragss
I'll tell ya right now that's it's your rims...look how far they are sticking out...that's gonna cause a lot of problems that most guys running 35's will never have. I didn't see your pic the first time I saw this thread but dude...you have WAYYYY too much offset. You have more than half your tire outside of the fender..I don't think a lift will correct this...but it might. Getting the entire wheelwell over the mid-point of the tire is about the only way to avoid any rubbing with that much offset.
bro I got the Rancho Lift and absolutely no rubbing...check how far my tires are sticking out. My tires are 37x13.50 R17, my rims are 17x10, backspacing is 4.5 (i think - i forget already - LOL)
However...I am runnning 1/2 inch spacers and did cut my inner fender well, and the underneath of my bumper. Without the spacers my tires was about a centimeter away from my control arm.
