alarm honk
Old 05-26-2007 | 11:09 AM
sgt940's Avatar
Default alarm honk
isnt the alarm supposed to hong when you lock doors--- i ahve factory installed alarm: Us new yorkers have o always check alarm is on!!! I wan to see my h3 the next daY!!!
[IMG]local://upfiles/2498/056A50A3AB884DAE9AACAAF4E3062917.jpg[/IMG]
Old 05-26-2007 | 12:08 PM
Dennis's Avatar
Default RE: alarm honk
Didn't you already post ths question somewhere else????
Old 05-26-2007 | 03:11 PM
littlehummerboy's Avatar
Make sure your horn is working (press on horn button). If it doesn't sound, check the horn fuse. If it is working, then make sure your RKE (Remote Keyless Entry) feeback is set right. The security system is ONLY armed when you use the remote to lock the vehicle, and has different types of feedback to let you know it has worked. Some honk the horn, some do not. Here are the instructions on how to set, and what the different modes are:
Remote Keyless Entry (RKE) Feedback
This feature allows you to program your Remote
Keyless Entry (RKE) feedback to a preferred
setting.
To set your choice for this feature, perform the
following steps:
1. With the engine off, turn the key to LOCK.
Do not remove the key from the ignition.
2. Press and hold the lock and unlock buttons
on the RKE transmitter at the same time.
Hold both buttons until the DIC display shows
the current RKE feedback mode.
3. To view the next available mode, press and
hold the reset stem for about two seconds.
Release the reset stem and press and
hold again to view each mode.
4. Once the desired mode is shown on the DIC
display, briefly press the reset stem to set
your choice. The DIC display will then clear.
The following are the available modes:
RFA 1 (default):
This mode flashes the parking
lamps when you press the lock or unlock
buttons on the RKE transmitter.
RFA 2:
This mode flashes the parking lamps and
sounds the horn when you press the lock button
on the RKE transmitter. This mode also flashes the
parking lamps when you press the unlock button
RFA 3:
and sounds the horn when you press the lock or
unlock buttons on the RKE transmitter.
RFA 4:
This mode disables RKE feedback. There
will be no feedback when you press the lock or
Old 05-26-2007 | 03:54 PM
Dennis's Avatar
Thanks Karl...I guess Sarge never got a OM with his H3...[&:]
Old 05-29-2007 | 03:55 PM
Little Monster's Avatar
ORIGINAL: Dennis
Must of got distracted from the cat tightening you nuts....
Old 05-29-2007 | 04:00 PM
Dennis's Avatar
justin67
12-18-2010 02:12 PM
machines
02-23-2007 11:17 AM
HummerGuy
20
12-22-2006 03:14 PM
khoolhandz
12-16-2006 12:30 AM
OUTLAW
02-16-2006 01:15 AM
