Air Ride
Old 09-28-2007 | 03:56 PM
markp3377's Avatar
Default Air Ride
I have a 2003 H2 with the air ride suspension. The servcie air suspension prompt came on. The ride height is now low in the rear. When you turn the key on, you can hear an actuator engaging about 5 times. It then goes out. Is there a common problem with this? Thanks for the help!
Old 09-28-2007 | 07:08 PM
CAMARO's Avatar
Default RE: Air Ride
TRY SPRAYING WD40 ON SENSORS AND LEVERS IT WORKED ON MINE........HAVE A GREAT WEEKEND TO ALL.......ANDY
Old 10-02-2007 | 06:15 AM
hilljob26's Avatar
what is spraying that on the sensors going to do,i understand the levers,but the sensors
Old 10-02-2007 | 11:26 AM
CAMARO's Avatar
THERE IS A LITTLE SHAFT COMING OUT OF SENSOR, ALSO WILL DISSAPATE WATER IF ANY...... ANDY[&:][&:][&:]
Old 10-02-2007 | 11:59 AM
I Like CRC power lube much better than WD40. No stain, lubricates, displaces water and in 100% electrical parts safe (increases conductivity). I learned from salt water boating, spray all your stainless and aluminum fittings/hardware and avoid squeeks and corrosion http://www.crcindustries.com/auto/co...=05006&S=N. Just my opinion.
Old 10-02-2007 | 12:17 PM
CAMARO's Avatar
I WILL ORDER SOME AND TRY ALLWAYS LOOKING FOR NEW STUFF......THANKS ANDY[&:][&:][&:]
itsxthexslim
04-07-2012 12:04 PM
XxCC3xX
08-23-2011 03:05 PM
myrddin
28
08-12-2010 06:46 AM
Brian C D
03-23-2010 08:30 AM
