air intakes worth it?
RE: air intakes worth it?
I do not see how you can go wrong with a K&N or other brand hi flowing filter. We have a small bit of AWD dyno info that suggests that the K&N filter alone is good for 8 HP in an 06 H3? An intake tube to replace the resonator box helps quite a bit more and can be made for a lot less than buying a kit, like D Vader's, and others. More air in means better efficiency, and should help squeeze all the MPG you can.
I put a quick fit Airaid in my 07, got a few gains in MPG and alot more punch in the pedal. I also added a TBS, not sure what it did for me because I did them both at the same time, some will tell you it does nothing. Thought that I would tell you anyway just for information.
Well, I just added the K&N filter for now. I was thinking of going with the Airiad intake but decided against it because it reuses the stock intake "accordion" tubing to the TB.Am I correct in that assumption?
