Adjust ride height sensor
ORIGINAL: Trainnwhls
Hi Does anyone know how to adjust the ride height for the air ride. The original owner lowered it and im not sure how it was done. any help would be great.
Hi
So I found out that the previous owner lowered the rear. The link for the Height sensor that connects to the rear upper control arm was cut shorter and moded. Im trying to find a set of stock height sensor links, not the whole sensor. If anyone knows where i can find them can you please post where. Thanks
Try and slide the Rod end on the controll arm toward the front the truck to get it raise up. But if they did cut them short you will need to custom fab new rods or just buy new sensors as its all one unit.
Hey HumminNBoatin do you have the air ride system? If you do and its stock can you measure the Link in the sensor top to bottom so i know how much longer I need to make the rod. for a new sensor they want 140 per side.
Or anyone with air ride suspension. I just need the length of the Link that connects the ride height sensor control arm to the suspensions upper control arm. If that makes sense.
mcrdeviation
11-11-2012 11:51 AM
